Whirlpool FH fault code
  • #22846
    geoffmackay
    Whirlpool AWM6141/S. Flashing FH on rinse cycle. Plenty of pressure to cold single valve and have changed fill valve. Ran 3 washes ok then has faulted again. Any offers?
    Geoff
    #196289
    johnmac11
    Re: Whirlpool FH fault code
    Hi Geoff,
    All the Whirlpool fault codes are in the “known error codes” thread, 1st thread in this forum.
    John
    #196290
    gegsy
    Hi Geoff
    It may be worth removing and cleaning the pressure bottle (next to heater) and checking operation and contacts on pressure switch. 😉
    SparkyP
    Hi Geoff
    Had one doing the same yesterday . Check the waste hose is not siphoning the water away. Has the customer moved machine? Also check the contacts on the pressostat.
    Hope this points you in another direction as you have changed the valve.
    Sparkyp
    #196292
    geoffmackay
    Thanks guys, haven’t checked pressure system. Went straight for the kill and changed valve.
    #196293
    Minge
    Hi i had this fault today. I cheacked the pressure switch and also cleaned outthe chamber by the element. customer phoned back and said same fault. do you think it will be the pressure switch.
    #196294
    timdowning
    Did you change the cold valve? Had a call yesterday where the valve was intermittantly playing up. I changed just the coil and all is well.
