Whirlpool Freezer AFB 126/H
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool Freezer AFB 126/H
Viewing 1 post (of 1 total)
  • #77038
    fuel__2001
    Ive had one of these freezers for quite a while and it stopped working. However i found if i gave the pcb (top of the freezer where the LED’s are) a slight tap or knock the freezer would spring to life again. I did a bit of digging about and came to the conclusion the relay on the pcb might be shot and for the small sum of a few quid i thought it might be worth a try to repair. Especially as these slimline freezers of 46cm arent made anymore, and as i live on a boat no other freezer currently on the market will fit into the space it would leave behind.
    The relay on the pcb was a Schrack T7NS5H1 – 24 – WG – A 10A/6A 24V 240VAC
    after more research i found that these relays aren’t made anymore and instead got myself one of these as a replacement
    Omron G5LE – 1A 24DC 10A 24VDC
    Freezer is back up and running and turns on and off without needing human intervention! 😀
    Hope someone finds this post of use
