Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Whirlpool Fridge and Freezer
- This topic has 9 replies, 3 voices, and was last updated 13 years, 1 month ago by
sverrirolafsson.
March 4, 2013 at 2:04 pm #74420
sverrirolafsson
ParticipantI have a Whirlpool Fridge and Freezer that has the following problems: The front control lights keep blinking always. Also every 3rd week or so the fridge goes to defrost. The cooling fan from the freezer stops and after a few hours and rebooting the unit the fan comes on.
The Unit is a Whirlpool Fridge and Freezer
520B RWW20 A/G
Circuit Board: ISPRACONTROLS 08535401R4
220-240V 50HzPlease advice.
Best regards 🙂
Sverrir OlafssonMarch 5, 2013 at 12:11 am #391499kwatt
KeymasterRe: Whirlpool Fridge and Freezer
What lights flash and what’s the 12NC number?
March 5, 2013 at 2:05 pm #391500sverrirolafsson
ParticipantRe: Whirlpool Fridge and Freezer
All the lights on the front control panel and the ice cube dispenser unit. Where do I find the 12NC number?
I can send, by attachments, images and a video of the flashing lights if you can send me an e-mail address. SO.
March 5, 2013 at 2:14 pm #391501kwatt
12NC is on the rating plate.
March 5, 2013 at 2:51 pm #391502sverrirolafsson
The following information is from the rating plate:
Class N-ST. S20B RWW20-A/G. 220-240V 50Hz 615W 160W IM 185W
Freezing capacity 12.0kg/24h Power cons.1.37KWh/24h Ref.fri.0.160 Type SB 540W Volume I Bruto 546-206-340
Neto 490-133-335 Low temp comp 22.
Service 8586 152 01010 11 0324 034448. Hope this helps. SO.March 5, 2013 at 3:09 pm #391503kwatt
12NC is: 858615201010
Nothing comes up on my Whirlpool info for that number, is it a UK model?
March 5, 2013 at 3:58 pm #391504don
ModeratorRe: Whirlpool Fridge and Freezer
kwatt wrote:12NC is: 858615201010
I wouldn’t think so K, the OP’s IP address suggests he’s in Iceland.
DonMarch 6, 2013 at 5:49 pm #391505sverrirolafsson
Right, I am in Iceland. The temperature lights for the freezer and the fridge are always blinking. The functional lights keep blinking when I select each function. Like if I select crust ice the light for that blinks. The panel light blinks also when selected. If I don´t select anything only the temperature lights are blinking. SO. 😕
March 6, 2013 at 7:06 pm #391506kwatt
Yeah, we can’t access info on Whirlpool sold outside the UK on our tech stuff, they’re a bit huffy about that.
March 6, 2013 at 10:03 pm #391507sverrirolafsson
Thank you for your time and efforts!
Regards
Sverrir -
