Whirlpool fridge ARG 992 at room temp
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool fridge ARG 992 at room temp
  • #26722
    howieleem
    I have a whirlpool built in fridge ( no freezer section) and it is warm inside.
    There is a rumbling noise as normal when switched on.
    There was a large lump of ice inside the top of the fridge which i have defrosted.
    After defrosting and switching on for about an hour the temp is down to only 13deg.
    #211168
    Dales-Electronic
    Re: Wirlpool fridge at room temp
    To allow us to give you more detailed information could you let us have the model and serial number of the fridge – Thanks
    #211169
    howieleem
    Re: Wirlpool fridge ARG 992 at room temp
    The fridge is an ARG 992 K/1/G/R, ser no. could be 853499215300, or 509919011259.
    The fridge has been on over night and has only got down to 10deg. There is frost forming at the top rear corner of the fridge.
    #211170
    gegsy
    Re: Whirlpool fridge ARG 992 at room temp
    It sounds to me like the refrigerant has become low, possibly down to a poor joint. Failing that you may be unlucky and either have a blockage in the system or a weak compressor.
    You are going to need pro help to identify which you have.
