Re: Whirlpool Fridge Freezer (American) – Ice Dispenser Pro
Hi, thanks for the reply.
Yes I have put the switch to cube….if only it was that simple!!
No problem when it is set to crushed, problem only occurs when whole cube ice is selected.
What is a PCB light? The only exterior light bulb flashes on and off……on reflection it looks like the WHOLE fridge freezer flashes on and off at 0.25 second intervals.
OK,THERE IS A 230 DC MOTOR IN THE FREEZER DOOR, IT GOS ONE WAY FOR CUBE AND BACK FOR CRUSH. U NEED TO NO DOES THE MOTOR WORK TWO WAYS,IF MOTOR OK THEN THE ICE CONTAINER MAY BE AT FAULT. I HOPE THIS WILL HELP
