Whirlpool fridge-freezer temperature anomoly
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool fridge-freezer temperature anomoly
  • #83908
    ronnie123456
    Ronnie Westhead
    I wonder if you could shed some light on a problem I’m having with my Whirlpool fridge-freezer. It’s getting warm when it obviously shouldn’t. I’ve found that if I turn the thermostat to the ‘ off ‘ position and then ‘ on ‘ to max, it fires up and brings the temperature down to the required level… but once it does, it switches off and doesn’t re-start unless I repeat the procedure. Does this indicate a faulty thermostat?
    I would appreciate some help on this. Many thanks, Ronnie. 😉
    #424163
    don
    Re: Whirlpool fridge-freezer temperature anomoly
    Hi Ronnie
    Welcome to the forums 😀
    Can you post up the model number and the 12 number code starting with 85 please, without this no one is going to be able to help I’m afraid.
    Don
    #424164
    ronnie123456
    Hi Don… thanks for your prompt reply my friend. I can’t seem to find much on the rear of the fridge-freezer other than a barcode. So it’s a Whirlpool 642016047. I hope this is enough to track it down.
    Ronnie 😉
    #424165
    don
    Model number etc is usually found on a label behind the salad bin in the fridge section 😉
    Don
    #424166
    ronnie123456
    Hi again Don..
    Yes, the 2 numbers I can locate are:
    ARC7412
    C8258W
    Are these correct?
