whirlpool fridge not getting cold
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum whirlpool fridge not getting cold
  • #10983
    djones
    I have a Whirlpool Compact Combi (ARG 648/WP) fridge freezer. A couple of days ago, I noticed that the fridge was at about 10-15 degrees (freezer fine). I turned the dial to 5 (full) and the freezer promptly froze solid but the fridge remained the same. After having read tips and advice from here and other places, I completely defrosted the unit for 24hrs, cleaned everything inside and outside (including the back) and switched back on. I checked the temp after 4 hrs and the fridge had gone down to 5 degrees but since putting all the shelves etc back in it only makes 10 degrees at best.
    I have also noticed ice building up on the back wall of the fridge although I have checked that the drain tube is unblocked. Is there some part / panel that I can remove inside / outside I can check behind for ice et al?
    Thanks.
    #143437
    Dave_Conway
    Re: whirlpool fridge not getting cold
    There are no removeable panels on this model I’m afraid as it’s not a frost free unit.
    It sounds to me like a system failure, can you confirm that the motor (compressor) is running all the time ?
    #143438
    djones
    Yes, I can hear the fridge working. I’ve turned it off again and will try to leave it defrosted over the weekend and then try again. Is there anything (any part) I can test and maybe replace?
    #143439
    Dave_Conway
    It won’t make any difference leaving it off I’m afraid, that only really applies to frost free fridge/freezers that have over-iced in the freezer.
    The important question is, is the compressor running constantly ?
    #143440
    djones
    Poo! I believe the compressor was running constantly but now I’ve switched it off I can’t be sure ?*&!? What does it mean if it is / isn’t? Sorry to sound thick!
    #143441
    Dave_Conway
    djones wrote:What does it mean if it is / isn’t?
    If it is then it’s a system failure, gas leak, compressor weak, system blockage possibly.
    If it isn’t, sometimes the thermostat can remain off for extended periods which will give the high fridge temperature.
    #143442
    djones
    OK, thanks for the help so far! I’m going to dismantle the bits I can to check for any blockages etc and failing that call someone out. Nobody in my area listed at repairs@ but I’m sure yellow pages can help.
