Model AWO/D5716..12nc. 859247415100
cannot find this exact model on SIOS. 😕
The heater is OC.
I normally just free the door seal/interlock, remove the three screws from bottom edge then pull down and out to remove the front panel.
This one appears to be held tight at the top edge.
Are there any clips or screws along the top of the cabinet front I should know about or is it just stuck with gunge from the soap drawer?
Also can anyone confirm that 481225928672 is the correct element for this machine?
