Whirlpool FRSS2VAF20/0 Display Flashes when doors open
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool FRSS2VAF20/0 Display Flashes when doors open
  • #89194
    srmiles
    Hi There,
    I have a Whirlpool FRSS2VAF20/0. WHen I open either fridge or freezer door the display flashes and there is an audible clicking noise. When the doors close the normal display resumes.
    I have replaced the capacitors on the main control board but no improvement.
    I was wondering if the extra power required to switch the lights on might effect the regulator on the control board and drop the voltage – hence make the front-panel flash ?
    Any thoughts ?
    Simon
    #440610
    Re: Whirlpool FRSS2VAF20/0 Display Flashes when doors open
    The operative word his is “might”
    and yes it might so unless you try it you wont know. if its the std small chips they are cheap so its a cheap experiment.
    there should also be a series fusible resistor into the board, measure it in case its gone up in value first
