Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool G2P DW1 bleeping when Im trying to watch the Footy
- This topic has 12 replies, 3 voices, and was last updated 19 years, 9 months ago by
wynny.
June 30, 2006 at 8:33 pm #18835
wynny
ParticipantHelp,
I am getting some serious nagging from the missus about the dishwasher not working just when Im trying to watch the footy!! The thing stops after 30 secs and starts bleeping. The light is flashing 4 times then a pause then starts again.Can anyone help? 👿
June 30, 2006 at 8:45 pm #180577Penguin45
ParticipantRe: Whirlpool G2P DW1 bleeping when Im trying to watch the F
Well, turn it off for the next ten minutes………. 😀
Four flashes is a draining error – water level drop not detected in the time allowed. So, some sort of blockage – filters, drain coupling, kinked/crushed drain hose; or a problem with the water level control switch.
Power off if you remove any panel; click the link below for a UKW engineer if you are unsure how to proceed.
Penguin45.June 30, 2006 at 11:06 pm #180578wynny
Thx Penguin45, Footy’s finished now so I have taken the machine out and straightened the hoses. Ran the washer again on a rinse and hey presto i could hear it working and it seemed fine. BUT, then i tried it again and this time I could hear no water going in and then it started bleeping again. Is there a way I can check the inlet path?
June 30, 2006 at 11:09 pm #180579gegsy
The second time you tried it, had you pushed the machine back to its original position and possibly squashed the fill hose?
June 30, 2006 at 11:17 pm #180580wynny
No, thats the strange part, its still out and the hose is straight, I even took the hose off and checked it and it’s fine.
June 30, 2006 at 11:20 pm #180581gegsy
Hi wynny
Any chance of the 12 digit number starting 85… from r/h side sticker of door inner just under the barcode please.Greg
June 30, 2006 at 11:22 pm #180582Penguin45
Remove filters, look into sump. On the right hand side is a black plastic grid. This fills up with grease, fat and other assorted crud and is probably the source of the problem – the machine thinks it’s full when it isn’t – next thing you know, fault.
It’s a twist fit from underneath – power off before removing any panel.
Penguin45.June 30, 2006 at 11:38 pm #180583wynny
Ok, the number is 8542 347 15810. I have the bottom plate off the machine (power is off) and I have taken the black grid off, it is as you say completley blocked with grease etc so I am cleaning it now. Also i noticed by the inlet is a white plastic tank that looks like it has brown sponge inside is this right? I aint going to bed till it’s done so it could be a long night!!
June 30, 2006 at 11:41 pm #180584gegsy
When you are cleaning that black thing (Water Indicator) be sure not to puncture the membrane beyond the grill, thus rendering it useless.
July 1, 2006 at 12:17 am #180585wynny
Penguin45, gegsy
Thx a lot guy’s, it’s been running now for 20 mins and no bleeps and lots of water going in and out. Loooks like I can get the bbq ready for tomorrow night now and watch the match without any nagging!!
Brilliant, Thx
MikeJuly 1, 2006 at 8:48 am #180586gegsy
The least you could do is invite us 😆
Have a nice BBQ, glad its all sorted for you.Greg
July 1, 2006 at 10:35 am #180587wynny
Its a bit far to come from Wales but Ill name a sausage after you how’s that?
p.s Its working great !!
July 1, 2006 at 11:10 am #180588gegsy
