Called to above appliance which is constantly beeping and giving 2 flashes of start button, acording to fault code guide this could be either circ motor or water leakage,the latter ive checked and its bone dry. Is this common and is there any way i can confirm b4 ordering. I tried diagnostics and m/c just pumps a while then reverts to above error code. Cheers Paul. Ive ran circ motor on bench with test lead and it runs fine.
HI, F2 is water leakage. Silly question but is it syphoning? Drain hose needs to be at least 700mm high. If its dry in base plate, can’t think of anything else. cheers Rob
