hi there looking for some help with my whirlpool g2p dwi dishwasher
starts to fill for about 30 seconds then starts to drain and the alarm goes off little led flashes 7 times pauses then 7 flashes ❓ any clues on whats wrong please .
thanks mitch
7 flashes according to the tech means the flow meter has failed. In practice it nearly always means there is a poor connection to the flowmeter….the cure undo, clean and remake the connections. The flow meter is situated in the airbreak chamber located at the left hand side near the bottom at the back.
Don’t forget to unplug before doing anything :zap:
cheers mate 😀 striped it down cleaned contacts up made sure connectors are giving good connection little impeller turns well flow meter has continuity in and out the other side
checked continuity to the pcb thats ok sill got drain then fill then drain again with 7 flashes and beeping 😕
Email to spares@ukwhitegoods.co.uk should produce the goods….don’t forget to quote the full model number and Pnc nnumber (12 digits long) both of which you’ll find on the rating plate.
