Whirlpool g2p DWI F4 draining fault indication
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool g2p DWI F4 draining fault indication
  • #89515
    AJL
    I have had this dishwasher for ten years now and it has been faultless until recently. The unit stops with an F4 error message now. So far I have done the following:
    Ensured that it is actually pumping out in a timely manner.
    Removed, stripped, cleaned and tested the pressure switch. I have had test leads connected to it, monitoring its operation on a meter. It appeared to be OK, but the spring action was feeble, so replaced it anyway.
    A test run then gave two complete cycles with no error. At this point it was put back into use but failed again next time it was used with the same error. Draining is still complete and timely.
    Next job was to strip the door and look at the control unit. The plug was pulled off and the operation of the switch monitored there, whilst the door was flexed. The idea was to look for an intermittent o/c or short in the door wiring. No problem was detected there, so a test run was done. That passed OK. Another run in normal mode 2 was carried out and agin it passed OK. The assumption is that there was some corrosion on the PCB contacts that caused it, but once again it failed the next time it was run.
    When the sump is empty, the switch is open and so the control unit should sense that, but the machine continues pumping until it times out, suggesting a short on the switch wiring to the control head. I have looked in vain for a service manual or a circuit diagram.
    Does anyone have any more suggestions please that will save me having to replace the unit?
    #441593
    Simon46
    Re: Whirlpool g2p DWI F4 draining fault indication
    Are you using a new pressure switch? Fat in the diaphragm makes it stick when warm.
    #441594
    AJL
    Hello Simon, thanks for helping.
    The switch is a brand new one. Today I have put it into test mode again and it passed. Put into normal mode 2 and it failed after just a few minutes. Back into test mode and this time it failed again. Always error four and with the drain pump running, although the sump is empty.
    #441595
    AJL
    Well tonight it has gone straight through on mode 3. I am starting to suspect dry joints in the control panel.
