Whirlpool G2P DWS/WH – No water coming in
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool G2P DWS/WH – No water coming in
  • #27022
    davidjgray
    My dishwasher refuses to fill with water. It did get blocked when my other half clogged it with rice and fish by not scrapping the plates before filling it. Ever since it has drained OK. The on light comes on steadily, there is no obvious fault, I have removed and cleaned and even air blasted the thing from both ends. I have had the bottom off and blown through and cleared every pipe I can find. There is no obvious reset feature on this machine, but I guess either it is “remembering” a fault, or thinks it is full of water, or the inlet valve has stopped working (which wouln;t appear to be related to being clogged – so I would be surprised if it were that). Any help appreciated. Service numbers are 8511 342 155109 and 990038 117305.
    #212315
    Re: Whirlpool G2P DWS/WH – No water coming in
    Cancel by holding down start button. Drain pump should run for one minute then you can start again and see what happens. Check fill hose didn’t get trapped/kinked when you shot the machine back under.
