Whirlpool g2p not washing upper shelf
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool g2p not washing upper shelf
  • #25678
    tennants1
    upper shelf not getting washed properly
    G2p DwI/1WH
    Service no 854234715810
    have already replaced sieve cover and cover as the supply pipe kept popping out.
    Thanks in advance for help.
    #207030
    Re: Whirlpool g2p not washing upper shelf
    You probably need to have a read of this:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
    tennants1
    When I rebuilt the the dishwasher I am getting continous beeps,then when opening the door the program start button is flashing four times along with the rinse button light on.
    Does anybody know what this means?
    #207032
    Four flashes is no drain detected in the time allowed. Did you disturb the level switch? That’s the black grid in the sump – the connector is very close to the circulation pump.
    tennants1
    Thanks for the reply,
    As you recommended I looked at the circ pump and it is perfect ,not in the condition in your photo Yet!
    I took the “black grid” out and gave it a rinse as it was out,but after running there was some drips from the bottom of the machine so have stopped it and switched the water off.
    I knew I should have put proper jubilee clips on instead of those dodgy “withdrawal method” jobs.
    Am still not impressed with the performance of this machine and dont want to waste much more money on it.
    What would you buy for £300 ,good deal on Smeg D1612CA £279(£150 off)?
    Fed up of wet floors!
    Cheers
    Richard
    #207034
    Personally I like SMEG (Our own d/w is one), a lot of the trade lads don’t. I’d stick another £100 on the budget and give yourself morte scope of the better quality stuff.
