Re: Whirlpool G2P61F/01SR oven takes ages to turn off after
Most ovens these days will over run the cooling system after use, how long depends on just how hot the appliance is when it’s turned off.
If it’s always taken this long to switch off you need to check that you have the correct ventilation for the appliance, but if it’s just started doing it then you may have a lazy cut-out…not a big or expensive job.
If you need an engineer then try the link below?
