If you remove the l/h side panel of appliance you will find the water matrix. On the bottom left of it is the flowmeter. Unfortunately the flowmeter comes with the water matrix, bummer 😥
Unplug appliance before attempting this :plug:
Hi Greg – I had a look at the water matrix and found that the flowmeter is indeed faulty. It has a crack in the glass reed switch which picks up the magnetic pulses from the impeller. It’s not responding when the impeller turns. Do you know if the reed switch, or its small circuit board are available separately from the matrix? If not, is the matrix available?
Thanks for your help – Kevin.
There is a kit that has two reed relay PCB’s in it (you choose the one you have fitted) part no 4812 310 19147.
This kit is available from spares@ukwhitegoods.co.uk
