Whirlpool G2PDWI/1WH Flashing 4 times?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool G2PDWI/1WH Flashing 4 times?
  • #29263
    tennants1
    On opening the door after continous beeps the on/off button is flashing four times then pausing?
    #222526
    clivejameson
    Re: Whirlpool G2PDWI/1WH Flashing 4 times?
    ….means it either hasn’t drained or thinks it hasn’t drained. Check the filters in the base and check for blockages at the end of the drain hose, if you still have problems it gets a little bit more involved with sensors and circuit boards in which case you might like to click the link below for a local engineer?
    #222527
    Aaaaaaaaaaaaaaaaargh!
    Double post.
    :p45:
