whirlpool G2pDwi
  • #82266
    dawnie d
    I have a whirlpool G2pDwi,and as normal switched on before bed last night,on opening door this morning to empty,found everything still dirty,the lights on the control panel are all on,but there is a quiet hum,it is hit in there,but there is water in the bottom that wont empty,ive tried switching off and changing programme,it has seemed to empty now,any ideas???
    thanks in advance
    Dawn
    #419362
    Re: whirlpool G2pDwi
    Clean the filter ?
    Bryan
    #419363
    dawnie d
    Bryan,you are a wonderful man,thank you so much,gave the filters a good clean and we are running beautifully once again,thanks so much
    Dawn
    #419364
    dawnie d
    Re: whirlpool G2pDwi,advice again please
    sadly my excitement was shortlived,the machine seems to have a strange noise,it seems to fill up but is very noisy, and not like it should sound,ive had the arms off and cleaned them also the filters,is there anything else i could do before calling someone out,i have no beeping or error codes,water is hot in the machine,and it seems to finish,but crockery is grubby
    thanks in advance
    Dawn
    #419365
    dawnie d
    it has a humming noise,and seems to empty,but water just sits in the bottom and doesent seem to be washing,any ideas would be great
    Thanks again
    #419366
    johnmac11
    Probably has a dodgy wash pump, read this which might explain your symptoms.
    http://www.ukwhitegoods.co.uk/help/fix- … -pump.html
    John
    #419367
    dawnie d
    Is this Most likely to be the problem John,or is there anything else i could check before ringing a man to have a look
    Dawn
