whirlpool gas hob only 2 sparking
Home Forums Public Support Forums Help And Support Cooker And Oven Forum whirlpool gas hob only 2 sparking
  • #86587
    iainc
    Hi Guys hope you can help
    I have a problem with my Whrilpool gas hob.
    The rear two are sparking when one of the knob is pressed but the front 2 dont spark, but when i light the front 2 with a match and press one of the buttons (when the gas is lit) to make a spark, they decide to work, but when i turn the gas off, the front 2 wont spark again ????
    many thanks
    Iain
    #432269
    Re: whirlpool gas hob only 2 sparking
    when the gas is lit the spark can jump the gap easier. chances are the spark electrodes are broken. if there is a crack in them the spark goes the easiest way. if the gas is not lit it goes through the crak but sparks in the normal place when lit.
    to effect a repair the hob would have to be disconnected and removed from the work surface
    to be honest its a lot less problems and safer to buy a gas match
