Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool gen 2000 G2PDWI/1. reverts back back to rinse prog
- This topic has 8 replies, 6 voices, and was last updated 19 years, 10 months ago by
TELL.
May 19, 2006 at 7:42 pm #17927
TELL
Participanthi,
been out to above d/washer, 1st neon (rinse)on contineous, and 5th neon flashing (start), also beeper going. switched of at mains cancelled prog, no lights flashing reset prog on cold pre-rinse. it drained, filled, washed , drained prog end o.k. reset onto 50 deg plate wash, drained, filled, washed,then drained the pre rinse. it pulsed to wash, it filled,the dispenser ejected tablet, then stopped and reverted back to rinse neon on con’t, again with 5th light flashing. could not reset to any wash, always went to above neon sequence. tested heater ok, ntc has a reading of about 67k,after cold water had been in (about 14degC) . any ideas out there lads, logically speaking is it the user board. (connect has it pt/n 5031688259775)
ps. checked wiring no breaks to ntc, and heater.motor working and d/pump ok.??
TELL..May 20, 2006 at 7:10 am #177061EFS
ParticipantRe: Whirlpool gen 2000 G2PDWI/1. reverts back back to rinse
Hi Tell
If you count the number of times that the start light flashes between pauses this will give you the erreo code.
Then go to the top of this forum to “known error codes” and all will be revealed.Steve
May 20, 2006 at 10:17 am #177062TELL
hi, EFS
the 5th light flashes at a constant rate, with no pause’s at all. had tried to count to see if there was a sequence, re: known error codes.
TELL..May 20, 2006 at 2:36 pm #177063DentedPorsche
That’s likely to be a single flash. NTC fault.
Brian
May 20, 2006 at 5:56 pm #177064TELL
brian,
any idea on the the readings i should be getting on the NTC,
TELL..May 20, 2006 at 7:09 pm #177065Flyman
Check your e-mails Tell. Hope it helps. 😀
May 21, 2006 at 8:30 am #177066funkyboogy
just an after thought -but may be worth checking,
there is a sump pressure switch just in front of the ntc, half turn takes it out, give it a good wash with hotwater, as it gets all gunged up, and can cause d/w to revert to fault condition..
cheers allyMay 21, 2006 at 1:53 pm #177067mbdas
Hi 🙂
I had one recentley were it was doing odd things and it turned out to be the pressure switch was leaking onto the NTC 💡 also NTC was 20meg
hope that helps 🙂 I changed both
markMay 21, 2006 at 7:13 pm #177068TELL
thanks for the feedback lads, certainly sounds like an NTC fault F1, contineous flash. but could the board be at fault, if i’m getting a reading of 67k at 14 degC through the wiring through the connecter off the pcb.
remember, i had the motor, d/pump and all other functions, running on the first test. and these boards are about £80.00.
TELL.. -
