Whirlpool Generation 2000 Oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Whirlpool Generation 2000 Oven
  • #74064
    Robbo1979
    Hi Folks,
    Got a wee problem with my oven, and i know nothing about these great gadgets being a man!!
    Put it on earlier to heat up my dinner (200oc) and it started sparking behind the fan and then started cooling down. The fan is still working as is the grill but i’m getting no heat from the oven settings…..???
    Any help would be greatfully appreciated
    Hungry Scottish Guy!!
    #389820
    Muv
    Re: Whirlpool Generation 2000 Oven
    The sparking you describe is more than likely coming from the circular heating element, which surrounds the fan…..
    Usually pretty straigtforward to replace, but if you dont want to attempt it yourself, i suggest you ring for an engineer
    Robbo1979
    Thanks Muv,
    Where is best to get the element on-line??
    #389822
    Muv
    If you can supply us with a full model number, or better still all the details you see from either the metal plate, or sticker… Then you should be able to get one from this very site..
    Robbo1979
    Martin ,
    Model No – BS0801/WH
    Type – FCEM6
    Long Bar code No – 8541 396 15050 14 9916 024870
    2.3kW
    Could you link me to the correct one if possibel??
    Scott.
    #389824
    johnmac11
    This one should fit your oven,
    John
    http://shop.ukwhitegoods.co.uk/48122599 … er-element
