Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Whirlpool Generation 2000+ Oven Fault
- This topic has 6 replies, 3 voices, and was last updated 15 years, 9 months ago by
jonnyfonny.
June 30, 2010 at 11:36 am #55546
jonnyfonny
ParticipantHello people,
I have a Whirlpool Generation 2000+ oven Model No. G2P 62F/SS.
I have recently moved onto my new house and have inherited this oven as part of the built-in kitchen.
My problem is, although the oven seems to make all the correct indications that it is up to temperature (5 little triangular arrows light up after 10 mins or so), when I cook the food, it doesn’t come out hot enough / cooked enough.
I’ve taken the fan guard of the back, and the element looks practically brand new. I ran the oven with the fan guard off to see if element got red hot. It was clearly warm as I could feel the heat when I opened the oven door, but it wasn’t red in colour. Should it be? Bearing in mind I set the oven to it’s highest possible temp.
I’m sure it’s a problem with the element or the thermostat, just not sure which. Any ideas?
Any help much appreciated!
Jon.
July 1, 2010 at 10:06 pm #324275clivejameson
ParticipantRe: Whirlpool Generation 2000+ Oven Fault
If the element is producing any heat at all then it’s fine, elements work until the day they fail then never work again.
Unfortunately these do not have a thermostat, they are controlled electronically so if there is an issue with the operating temperature you will need either a new control pcb (£90ish) or a temperature probe (50ish) or possibly even both.
😥July 6, 2010 at 6:32 am #324276jonnyfonny
Thank you for your response.
Looks like I might be better off opting for a new oven. Don’t want to start throwing new parts at it, when it’s not guaranteed to fix the problem.
This is probably the wrong forum, but any recommendations on integrated ovens around the £500 mark? Any particular brand I should be looking for in regards to reliability?
Thanks again
Jon.
July 6, 2010 at 7:52 am #324277don
ModeratorRe: Whirlpool Generation 2000+ Oven Fault
Hi Jon
Is it a single or double oven you are looking for? If it`s a double is it to go under the worktop or at waist height and up?
Don 🙂July 6, 2010 at 8:33 am #324278jonnyfonny
Hi Don,
It’s a single under-the-worktop standard affair. Just noticed the one I currently have runs off a standard 13amp plug, so would probably require something similar as the fuse box is at the other side of the house 🙁
Cheers
Jon.
July 6, 2010 at 8:45 am #324279don
ModeratorJuly 6, 2010 at 12:09 pm #324280jonnyfonny
Hi Don,
Thank you so much for your help.
I’ll check out the Neff oven you suggest, and possibly a couple of Bosch ones as well.
Cheers again
Jon.
