hullo folks got a hdwm100 9kg big beast
the fella brought it in saying it does not complete its cycle when i try it on any cycle it will lock i can hear the solonoid actually fire if i try the door it is locked it will then take water for 10 seconds then i hear the solonoid fire again and it unlocks
it does this on any cycle including spin only which makes me wonderif
1door lock is faulty and not staying locked
2pcb is faulty there are 3 on this machine one at base for motor one at top rear and one behind fascia panel have inspected all and seem visably ok
3 pump or motor fault motor reads through so does pump
but neither will actually activate so i am unsuire as to whether this machine tests them b4 it starts and aborts when it find a fault
also are there any diagnostic routines for this or error codes as i dont seem to be able to find any but would assume that there are and its just me being blind
realise its an odd one but ideas please 😀
