Whirlpool HD WM1100
  • #62230
    This 9Kg AFL is dead apart from the LED dispay which reads 88.8. I guess the fault is with a module but there are 3 so which one is likely to be at fault? Also, a tip for anyone sent to one of thes machines, make sure you take a tiny T6 torx screwdriver for removing the front modules.
    #349301
    Re: Whirlpool HD WM1100
    Looks like I can’t edit my post as I had only given the model number off the fascia. It’s actually AWM9000 8570 084 15002.
    According to Masterpart the boards are 481221479825, 481221479827 and 481221479772.
