whirlpool heavy duty wm
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts whirlpool heavy duty wm
  • #54979
    tash
    hi I’m trying to get the correct part no for a drain pump ,the mod no is 3rgsc9400rlo..ser ct0101039 type 111..I know the part no isn’t 4819 360 18249 because I’ve just received that one and it isn’t the same drive size ..any help would be appreciated ..tash
    #321593
    johnmac11
    Re: whirlpool heavy duty wm
    There are two different pumps for the american top loader the only difference is the one has both hoses that are the same diameter and the other has two different size hoses fitted to it.
    If the pump fits on to the hoses then it is the correct one and the you have probably got the tophat coupling stuck inside the old pump.
    There is an earlier thread discussing this problem HERE
    John
    #321594
    tash
    thanks..the outlets are a different diameter too so it’s the other pump part no. not 481936018249 ..do you know what it is? cheers
    #321595
    johnmac11
    part number 481936018211
    John
    #321596
    tash
    thanks john.. much appreciated 🙂
