Whirlpool ice maker
  • #81793
    paolo
    I have a Whirlpool fridge freezer, model number S20D RSS33, with a faulty ice maker.
    I need some help with troubleshooting. I have removed the unit and tested the motor, so know that it works, done the optics test, flashing red light which goes continuous upon closing the flap but am at a loss as to what to try next.
    #417737
    paolo
    Re: Whirlpool ice maker
    Nobody have any ideas?
    #417738
    lee8
    Would help if you stated what has occurred that makes you believe it’s faulty.
    #417739
    paolo
    Ice maker is not making ice, as I said, I have removed it and tested the motor, which works, and performed the optical test, flashing led, which goes solid, now at a loss as to what to try next.
    #417740
    Mark Davies
    Just had one of these in bits .
    it could be either water supply to the ice maker or the dreaded relays and caps on the main board ?
    Any other symptoms like spluttering water from the water dispenser ?
    The IR unit has been reported on the net as a possible cause. Its on the left top of the freezer ( with the flappy door ) . This unit is a receiver of some description and is accessed removing the three screws .
    https://www.youtube.com/watch?v=N988_wHptUw
    #417741
    lee8
    By not making ice. You mean their is no water entering the tray or the water is not freezing.
    As much info as possible please, personal opinion is a waste of breath.
    You wouldn’t march into your Dr’s, state I don’t feel well and expect a complete diagnosis from that, or maybe you would, which isn’t going to help you.
    #417742
    paolo
    Hi Mark, water dispenser works fine, circuit boards were replaced several years ago after the usual click click click.
    I also replaced the optics, both panels many years ago, so they should be good, wondering if it may be the inlet solenoid.
