Whirlpool/Ignis oven fault codes – F06
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool/Ignis oven fault codes – F06
  • #76197
    twicknix
    Can anyone tell em what is F06? How is it related to the self cleaning mode?
    Regards
    Matt
    #397589
    twicknix
    Re: Whirlpool/Ignis oven fault codes – F06
    I’m guessing that this fault code does not exist?
    #397590
    Hi Matt,
    We need the model number to be sure (12 digits, starts 85….) but on some pyro models there is an F06 – door lock failure, door locks on self cleaning cycle due to extreme temperatures, if it doesn’t lock it errors out. check door lock or if ok, replace module – but do get the model number if you want to be sure!
    Alister
    #397591
    twicknix
    Alister,
    854190915000
    I replaced the module on the other day as the original was showing F03 and all it needs reconfiguring but I didn’t have that information to hand. I have the instructions on how to do it as it came with the new module.
    I did wonder about the door lock as it appears to be quite common fault with self cleaning oven. I asked the owner not to use the self cleaning for the time being until I find out what’s going on. The oven is working as it can be used for cooking but not self cleaning.
    Do let me know the outcome so I can give the owner a call.
    Many thanks
    Matt
