whirlpool (Ikea) DWF416W Flow meter
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool (Ikea) DWF416W Flow meter
  • #20645
    bobokines
    I have the above dishwasher with a ‘7 flash’ error code showing after about 10 seconds fill.
    The known error codes lists shows this as a ‘flow meter failure’
    I can’t find a flow meter listed for this appliance.
    Can anyone tell me where it is situated on the machine, how does it work and does it have a different name?
    The machine has been installed incorrectly .. (it’s sitting on two blocks of wood under the base but not on the feet.
    I can’t get the kickstrip inspection panel off as the weight of the machine is pushing down on the panel. 😡
    I can’t pull it out as it’s wedged in with another block of wood hammered in over the top of the machine. 👿
    I have told the customer (letting agent) that they will need to get it out and I will come back and fix it.
    Any help will be much appreciatted.
    Bob
    #187842
    gegsy
    Re: whirlpool (Ikea) DWF416W Flow meter
    Hi Bob
    The flow meter is incorporated in the water tank on the L/H side p/no 481241868147.
    Can also be a kinked fill hose or low water pressure causing same fault 😉
    ali-p
    Also be careful with the wires between the c/b & the flowmeter card, we sometimes get problems there
    #187844
    bobokines
    Many thanks, I will let you know how I get on.
    Bob
