Whirlpool Integrated dishwasher ADG7540 help
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool Integrated dishwasher ADG7540 help
  • #45314
    Geeboy1
    After programming the machine immediately reverts back to the rinse light being on, whilst emmiting an audible sound every second and the start LED light flashes continously without pausing for ever!! During this time the pump will run for abour 30 seconds and then nothing else happens.
    We have been through tthe reset mode on a number of occassions however this has no effect on the machine, just the same problem occurs.
    Does anybody have anyideas of what’s wrong? or how to solve the problem??
    All help much appreciated
    #285285
    Re: Whirlpool Integrated dishwasher ADG7540 help
    Constatnt flashing is F1 – temperature sensor failue. You need THIS.
    Its a twist fot from undeneath. Power off first, please.
    Geeboy1
    Thankyou very much it works now : )
    #285287
    mogy
    hello Geeboy1, I just posted a new topic asking how you swapped the NTC. There is a chance you may not read my post so I thought I would ask you directly 🙂
    Any information you can give would be great.
    G
    #285288
    mar
    Just a suggestion which may save some of you a lot of trouble!
    My integrated machine, ADG7340, had the continuous bleeping & flashing fault suggesting NTC needed replacing.
    Ordered new part & received next day (excellent service!) but made no difference.
    Eventually tested wire from control pcb to NTC & found break in wire where the wiring loom enters the bottom of the door! (you need to take off cabinet door to see it.) The plastic protective cover had split & because the wires are so thin one of them had broken with the movement!
    Pulled a new length of twin twin through with the old one & patched in the plugs on the ends – good as new!
    Now have a brand new NTC spare! – don’t know if I’ll be able to return it OR IF ANYONE OUT THERE WANTS TO MAKE ME AN OFFER!
    Hope this helps.
