Whirlpool integrated fridge freezer model CB18M/1c/FAN
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool integrated fridge freezer model CB18M/1c/FAN
  • #95571
    DWD
    I have noticed that the frost free larder part is not keeping cool it is just 15 degrees but the freezer seems good. I have a feeling that this is a compressor issue and therefore a scrapper but I would ask if it is possibly the thermostat?. I can source a replacement and it looks straightforward to fix. Any advice appreciated.
    DWD
    #460772
    from what I can see from digging around is you have a non frost free freezer so the thermostat is in the fridge. if that is the case your compressor must be running 24/7 which is costing you lots in electric
    if all this sounds correct then its time for a new one
    DWD
    Thanks for replying. The freezer does frost and the larder part is frost free. The thermostat is part of the temperature control/light unit in the larder part. Are you saying that a freezer defrost and new thermostat would cure the problem or is it kaput?
    DWD
    #460774
    if the compressor is starting and stopping then its possible a new stat would cure it. if the compressor never stops then its time to quit
    DWD
    okay thank you for that I will take a closer look. I think it is at the end of its life and uneconomical to repair.
    #460776
    DWD
    I defrosted and tried it again but still the same. I pulled it out and ordered a new one for tomorrow. I do not think it was that old. I have a freezer in the garage that is 25+ years and still running well, just shows you.
    Thanks for the help
    DWD
    #460777
    the older stuff cost more in real terms so its made better. your unit could be up to 10 years old which is not bad these days
