Whirlpool just pumps?
  • #43041
    Whirlpool washer (AWO/D4505) and all it will do is pump….select any programme and the first thing it does is the door locks and then just pumps…forever! 🙁
    Any thoughts over and above what I’ve checked already? 🙂
    (Machine’s just 14 months old and very lightly used by the way)
    #275764
    clivejameson
    Re: Whirlpool just pumps?
    What have you checked so far Martin?
    #275765
    Have you checked for a short circuit water valve solenoid? (My favourite rare fault.)
    Mike.
    #275766
    leavemetogetonwithit wrote:Have you checked for a short circuit water valve solenoid? (My favourite rare fault.)
    Mike.
    Everything but that Mike, there’s continuity to each coil mind you, though as it’s one of those tiny connectors with just 3 tags to a double valve I’m unsure at this point what the resistance should be on them anyway? 😕
    #275767
    these would be my next moves
    check for earth faults on pump if neutral switched
    check voltage at pump if 110v triac failure had a servis do this recently
    check triac in programmer
    hope this helps
    No earth leaks, the pump is fine. The machines only done a few washes in it’s entire life.
    What I forgot to add was that you can press the ‘Reset’ button on the fascia ’til you’re blue in the face and it wont reset. 😕
    #275769
    Martin wrote:there’s continuity to each coil mind you, though as it’s one of those tiny connectors with just 3 tags to a double valve I’m unsure at this point what the resistance should be on them anyway? 😕
    Take it you mean continuity through each coil. So you checked them with a blue plastic screwdriver with a red led in it? Try again with a meter – they should certainly be 1k ohm plus each and most probably 3.5k. If not I’m on a winner.
    Mike.
    #275770
    hi martin did you gat any further with this problem
    electrofix wrote:hi martin did you gat any further with this problem
    I told customer that my diagnosis was the module, the replacement cost of which is prohibitive, so machine scrapped! :rolls:
    #275772
    pity got a complete module here of a scrapper
