hope someone can help with this dryer,the fault is that
when you press the start button it turns the drum for a few seconds and then blows a small inline fuse in the wiring loom.
have traced the wire from the fuse one goes down to a front stat in base
the other goes to the control panel where it splits into 3 wires
1/to the timer 1/to the start button 1/to the buzzer
I have checked the heater /motor and stats all seem ok and have no leak to earth on insulation
any ideas would be of help . and thanks for looking .
thanks 🙂 :rolls:
Re: whirlpool large American tumble dryer 10 kg 110 volts
You sure about the run winding on the motor? Most of these have a centrifugal start device, which can take a second or two before it throws the run winding on,
I think it has got a centrifugal start device on the motor will check it out but have already had megger on windings and they seemed to be fine .
thanks for your info 🙂
