Whirlpool lpr 600 fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool lpr 600 fault
  • #15728
    Eugene
    Hi, My dishwasher has ceased fundtioning correctly, it washes for a while, then stops emitting a bleep every 2 or 3 seconds. when opened there is water remaining in the bottom. it also seems to be washing cold. Any ideas what the problem is? Cheers Eugene.
    I just noticed the led at the on/off switch flashes four times.
    #166128
    Re: Whirlpool lpr 600 fault
    hi eugene
    this fault code is normally due to the waste pump failure or outlet pipe kinked ect.
    its basicly the appliance has not been able to pump the water out,check you outlet under the sink otherwise its an engineer visit.
    bryan
    #166129
    Eugene
    Thanks Bryan
    Ill take a look at the outlet.
