Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Whirlpool LPR273 Combi Fridge Freezer (70/30) common faults
- This topic has 4 replies, 4 voices, and was last updated 16 years, 7 months ago by
Mike I.
September 8, 2009 at 1:41 pm #48432
Mike I
ParticipantHi there
We have a Whirlpool LPR273 Combi Fridge Freezer that is almost 6 years old. Unfortunately the fridge doesn’t seem to be chilling at all well even on max setting. The freezer works fine.
Are there any common issues with this model or things to check?
Cheers for any infoMike
September 8, 2009 at 2:07 pm #296575spimps
ParticipantRe: Whirlpool LPR273 Combi Fridge Freezer (70/30) common fau
Simple set up,the fridge will be struggling either because of a lack of refrigerant or poor compressor performance.
Engineer or new fridge req’d 🙁September 8, 2009 at 3:22 pm #296576Mike I
spimps wrote:Simple set up,the fridge will be struggling either because of a lack of refrigerant or poor compressor performance.
Engineer or new fridge req’d 🙁Cheers spimps – I guess we’ll try a local engineer to see if refrigerant has leaked out
September 17, 2009 at 7:37 am #296577brysat
Don’t know if this is a side-by-side item, but if it is, the fridge is cooled by air blown in from the freezer. This is the job of the evaporator fan, usually located half way up the back of the freezer behind a panel. This could be bust or you might find a huge chink of ice behind this panel blocking the air flow. There is also a thingy (technical term) at the top left of the fridge which seems to be an electrically operated louver used to control the cold air entering the fridge. I don’t know what it’s called but mine is broke so I jammed it open and at least the fridge now works (it’s summer; I probably can’t leave it like that for the winter.) My problem is, is this gate broken, is the temperature sensor broken, or is the fault in the control board that controls everything? Does anyone have any ideas?
September 17, 2009 at 8:21 am #296578kwatt
KeymasterRe: Whirlpool LPR273 Combi Fridge Freezer (70/30) common fau
brysat wrote:Don’t know if this is a side-by-side item
It’s not I’m afraid.
