Whirlpool/Maytag – Tumble Dryer Motor Glue
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool/Maytag – Tumble Dryer Motor Glue
  • #79654
    Hollytree_Technical
    Hi all
    I have been asked to sort out a Whirpool semi commercial tumble dryer where the motor was getting jammed with lint – I have cleaned it out as much as I can and it is running better but still feels stiff, as the motor is electrically ok I would like to split it to clean it properly but notice that the end frames are glued on (appears to be a grey glue) – does anyone know what the glue is or what a suitable alternative would be as replacement motors are expensive and special order.
    Jem
    #410123
    Re: Whirlpool/Maytag – Tumble Dryer Motor Glue
    if it were me change the motor. you may be able to split it but getting it aligned again and getting a reliable joint could be a problem.
    if you want to try I would use Araldite
