Whirlpool not spinning
  • #34907
    pmb
    Whirlpool washing machine AWO/D4305 18 months old,
    Works ok untill spin, Distributes then starts to ramp up speed then cuts out
    before spining then after about 20seconds starts distributing again and keeps repeating this sequence.
    Suspect pressure switch,
    Anyone had this fault.
    #244424
    Check motor 1/2 field coil… at programmer side of motor wires connector…
    #244425
    pmb
    Re: Whirlpool not spinning
    Thanks alot Baron i will give that a check if the customer calls back, just spoke to him and it is working for now don’t you just love intermittant faults? 🙂
    #244426
    But could be also pressure switch/press.sw. chamber/wires/connectors… those not see it’s empty…
