Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool “not spinning sometimes”
- This topic has 9 replies, 6 voices, and was last updated 16 years, 10 months ago by
subs.
June 5, 2009 at 10:54 pm #46239
subs
ParticipantAWO/D4305. Been to this machine for letting agent for leak and not spinning sometimes. Sorted leak but although tennant said machine would sometimes not spin at end of programme, it would spin if put on just spin cycle. When i checked it out all seemed ok brushes, pumping out fine drained and spun everytime. Got called again to say machine still doing it after every 4th to 5th wash and sometimes wont spin on just spin cycle now. Could it be pressure switch causing this intermittant fault? Any ideas before i go back would be appreciated.
Subs
June 5, 2009 at 11:44 pm #288656Penguin45
ParticipantRe: Whirlpool “not spinning sometimes”
OOB?
June 6, 2009 at 7:46 am #288657Martin
Crudded up air bell I expect. 😉
June 11, 2009 at 10:58 pm #288658subs
Went back to this machine and could not get it to spin at all. Checked pressure system all seems ok. Pressure switch seems to operate. Tried it with and without load in. All it seems to do is drain, distribute then stop. It does this a few times then stops. Although it did not spin this time it had spun before for me and the tennant, so im thinking being intermittant it may not be board (tightened all connections). Ive wasted a lot of time on it now so im even reluctant to gamble £30 on a pressure switch. Am i missing anything?
Subs
June 11, 2009 at 11:12 pm #288659robstech
ParticipantIts probably aborting an out of balance load, ask customer if she notices it missing the spin more often on small loads.
June 12, 2009 at 9:12 am #288660subs
I thought about the out of balance senario but dismissed it when it would not spin with no load. Now i know some machines dont spin with no load in it but i had this spinning empty before. Also would the OOB be happening so often?
Subs
June 12, 2009 at 9:43 am #288661Martin114
broken wire on motor plug loom maybe?
June 12, 2009 at 11:05 am #288662Martin
subs wrote:Ive wasted a lot of time on it now so im even reluctant to gamble £30 on a pressure switch. Am i missing anything?
You can discount the pressure switch if the machine fills on wash, tumbles and heats OK. And if the nmotor does turn then chances are the wiring harness/motor plug is also OK.
Faults are more likely on the wear and tear components so armature insulation is a caution as well as the brushes of course. But it will also not spin if the heater is a fault. Any insulation failings there are highly likely to give these symptoms.
When the fault occurs does the ‘Service’ LED flash I wonder?
June 12, 2009 at 4:17 pm #288663jackster
This model is a nightmare for out of balance, bet that is what it is.
June 16, 2009 at 10:21 am #288664subs
Thanks for everyones input.
The letting agency has decided to get a new machine to keep the tennant happy (or quiet). I think the tennant was determined to get a new one anyway.
Im convinced there was nothing wrong with the machine and it was probably an OOB problem.
Its frustrating when you dont get to the bottom of a problem and its possible that a perfectly good machine may be scrapped.Subs
