The customer says that the oven timer seems to have a mind of its own, turn on power and the display comes on. Set the clock, turned on the oven and it seems to work. every now and then the oven beeps, the clock display went funny, the hour digit was flashing as it if needed setting in the time. Then it set itself and the oven powered up then went out along with the beep. Been doing this on and off.
Is it the timer that is malfunctioning or the pcb module?
Thanks Matt
