Morning all , was out looking at friends whirlpool oven AKZ150/WH, prblem with the oven , when you turn oven on it runs for a few seconds then just turns off, does it relate to powerboard fault or temperture sensor?
I assume by turning itself off you mean dead, if so check for power going to the main board once it is dead, and if there is power there then it will be the problem.
