Whirlpool oven AKZ151/IX
  • #77166
    senseib
    Hi got one of these ovens again that displays STOP, tried resetting it in the usual way but wont, so suspect pcb needs changing, but is it just the display (part number 481213008762) you change to put it right or is it something else?
    Anyone had this before and know for sure ?
    Brian
    #401240
    Andy jones
    Re: Whirlpool oven AKZ151/IX
    I’ve had to replace the button in the past, I know it sounds stupid but did you have selector switched to off before resetting. Got caught out like that myself
    #401241
    senseib
    Hi Andy,
    Yes tried all combinations no luck, wont budge off STOP
    #401242
    EFS
    Had one like this recently and was a dry soldered joint on display pcb.
    Steve
    #401243
    spanner51
    If you are sure its not the button, try turning the selector back and forth a few dozen times while spraying in some switch cleaner. It has worked for me a few times
    Graham
    #401244
    alster
    Its allways been the button for me! Ckeck it with a meter,just because it clicks dont mean it works! Alan
