Whirlpool oven configuration codes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool oven configuration codes
  • #81846
    snig
    Just fitted a power board to a AKZ196/1X oven. Comes with full instructions for configuring but you need a code which should be on the rating plate, however i can’t see it !According to the instructions it should be between model no. and service code but nothing on this label ?Any whirlpool specialists out there who might help ? Service code is 858519615021
    #417876
    johnmac11
    Re: Whirlpool oven configuration codes
    The configuration code for 858519615021 is 36
    HTH
    John
    #417877
    snig
    Thanks john, i’ll go back today and try that. Out of interest should that be on the rating plate normally,as suggested on the info sheet or am i reading it wrong?
    #417878
    johnmac11
    In my time with Whirlpool the configuration code was immediately after model number on the rating plate so in your case it would be AKZ196/1X **.
    It is usually done in a slightly larger font and the code would be a number between 1 and 39.
    On the later models the code is in the service manual.
    John
