Whirlpool oven door (inner) – how to replace it?
Home Forums Public Support Forums Spare Parts Help Whirlpool oven door (inner) – how to replace it?
  • #28494
    thaddius
    Hello,
    I have a whirlpool oven model AKP511/WH/02 and I need to replace the inner door fitting containing the fitted glass. I have purchased the replacement part but my question is how do I remove the old fitting ?
    I can see there are 2 screws at the bottom of the door but I cant get access to them to unscrew them.
    Do I have to remove the hinges? If so how do I do that?
    I have failed in my search for an instruction manual, I got no instructions with the part and I’m now stuck 🙁 So I’m hoping there is somebody out there who has done this before and could maybe give me an idea of where to start?
    Thanks in advance,
    T
    #218582
    Re: Whirlpool oven door (inner) – how to replace it?
    Taking the door off the oven will allow you total access. Each hinge will have a locking clip which you flip out in order to lock them.
    Tube of this stuff would have been much cheaper:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=302
    thaddius
    thanks for getting back to me.
    I ‘think’ I have now lifted up the clips you mention but they don’t seem to have done much. Do you think the hinge is attached to the door or to the oven?
    I am afraid to use to much force, should it just slide out? or do I need to ‘lift & pull’ or wiggle it about a bit?
    I dont seem to be getting anywhere fast with this 🙁
    T[/img]
    #218584
    Check the link here:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=3771
    A couple of “typical” examples – they are all basically variations on the same theme.
    thaddius
    Excellent Penguin45, just the link I needed.
    Managed to get the door off in seconds. I did manage to put it back on again which was admittedly more difficult and took me several goes.
    Turns out I will need to buy some of the glue you mentioned in a previous post too to join the new inner door to the outer door as I had thought that was only held by screws.
    Anyway, I’m getting there slowly but surely.
    Thanks again,
    T
