Whirlpool Oven stopped working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Whirlpool Oven stopped working
  • #78415
    AKA THE GUEST
    Light comes on and fan is running but oven doesnt heat up. The element at the top is not going red but not sure if this is just the grill or not ? Model Number is FCES6 G2P60C/01SR/SS (854188415010)
    Any advice would be appreciated, thanks.
    #405573
    Re: Whirlpool Oven stopped working
    The element you need to look at is the one that surrounds the fan!
    #405574
    Andy jones
    Not sure this one has a fan element, had one recently with the base element gone
    #405575
    don
    Andy jones wrote:Not sure this one has a fan element, had one recently with the base element gone
    From the info I have I would say base element along with a combined top oven and grill element.
    OP should be testing the top element with the power disconnected :zap:
    Don
    #405576
    AKA THE GUEST
    Thanks guys, there is no visible element in the base of the oven unless i have to remove the cooker from its housing to view it ?
    #405577
    Andy jones
    Agree don. I expect one has been gone for a while
    Have you noticed it has been taking a lot longer to heat recently
    #405578
    Andy jones
    You have to take oven out
    #405579
    AKA THE GUEST
    Yes, it does take a while to heat up, so could be both elements gone, whats the easiest way to check them ?
    #405580
    Andy jones
    You need a multimeter. Some times it’s obvious by looking at them but you need to know what you’re doing
    #405581
    AKA THE GUEST
    Didnt need the multimeter, both upper and lower elements were burnt out/broken ! parts with delivery are £120, so at 4 years old its not worth repairing. Wife doesnt use it much, what does anyone recommend for sub £150 ?
    #405582
    AKA THE GUEST wrote:Wife doesnt use it much, what does anyone recommend for sub £150 ?
    Gumtree?
