whirlpool parts
  • #18958
    abbots
    hi guys,
    wpl S20 ob
    858615215000
    american fridge freezer
    a customer wants fridge door seal,i haven’t been out to see it yet,thought i’d check some prices out first.doesa the seal come off or do you change the door?is it an easy job?
    wpl AWZ220 857522015000 TD
    customer says no heat, stats and heater are ok,only leaves the timer if i can remember right,everyone agree ?
    cheers.
    john
    #181060
    bzz67
    Re: whirlpool parts
    have you checked the green exhaust thermostat at the front of the tumble dryer, part number 481227128369.
    #181061
    abbots
    Re: whirlpool parts
    no i havent checked it,where is it on the dryer?do you need to drop the drum out to test it?
    jk
    #181062
    Dave_Conway
    Re: whirlpool parts
    The fridge/freezer fridge door seal is part number 481246688644 but I would double check that is comes off as some don’t but the seal is still shown as a seperate part. The list price is £46.68 ex VAT.
    The front stat can be got at through the plinth part normally 😉
    #181063
    abbots
    Re: whirlpool parts
    cheers dave,
    there isn’t a plinth on a AWZ220 is there?i thought they went down to the ground at the front,i may be wrong because i haven’t been and had a good look yet.
    john
    #181064
    SparkyP
    Re: whirlpool parts
    Hi Abbotts
    The exhaust stat on this air vent dryer is under the drum and drum removal the only optoin. Green stat, 2 wires to it, you canot miss it. The stat dave is on about is only on the condensor dryer behind the front kick plate and is yellow.
    Sparkyp
    #181065
    abbots
    Re: whirlpool parts
    cheers lads,
    john
    #181066
    DentedPorsche
    Re: whirlpool parts
    The door seal is available as a spare part, however, the old seal has to be cut off and a channel to receive the new one cut into whats left of it. Be prepared to spend a long time on this job, it’s not an easy one.
    Only ever did one, always ordered a new door after trying the seal change.
    Brian
    #181067
    abbots
    Re: whirlpool parts
    thanks brian,
    sounds like a new door it is then,anyone know the part no and approx price so i can quote the customer
    john
    #181068
    Dave_Conway
    Re: whirlpool parts
    abbots wrote:anyone know the part no and approx price
    4812 416 19402 at £175.33 ex VAT :eeek:
    #181069
    abbots
    Re: whirlpool parts
    thanks dave.
    john
    #181070
    bzz67
    Re: whirlpool parts
    the tumble dryer stat can be removed without taking the drum out if you have a small ratchet with torx driver bits, ( OTHERWISE ITS EASIER TO REMOVE DRUM )
