service number 8586 152 15000
Hello having trouble with this one. Freezer is showing CF fridge showing D. Last month found air diffuser iced up in fridge section so I replaced it. Worked for a month now have the above problem and the alarm going off. Took panel off inside freezer section last week and found lower part of evap iced up so defrosted but its come back again today. Anyone had this? I’m thinking CF may be the board but have no idea. I would appriciate any advice that does not involve a refund.
Hi Brian,
Thanks for the reply there is only one other number above a bar code 11 0247 024177 not sure if this is serial number as it doesn’t say. Apparently the front board is a 1-4 week special order so that will go down well with the customer.
