whirlpool S20BRBB20 858615215000 not freezing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool S20BRBB20 858615215000 not freezing
  • #38113
    mbdas
    Hi 🙂
    Not been to this yet but he says its not freezing it just makes a clicking noise ❓ I have not repaired any of these ones before but its for a friend so I said I would take a look . can anyone give me some info on it
    Please 🙂
    Mark
    #257758
    subs
    Re: whirlpool S20BRBB20 858615215000 not freezing
    If the clicking is coming from the control board at the back and the compressor is not kicking in then the board probably needs replacing.
    Subs
    #257759
    lerch
    If pcb at rear is clicking then the relays have gone – new board.
    If the compressor just clicks then new compressor I am afraid. 🙂
    #257760
    DentedPorsche
    Hiya,
    If you’ve determined that the board is at fault you’ll need to check the serial number to tell if it requires just the rear board or both. If the first six numbers of the serial are less than or equal to 110330 you’ll need both boards, after this you only need the rear board.
    Brian
    #257761
    mbdas
    Hi 🙂
    Thanks For all the advice I’m going to it tomorrow pm so I will let you know how I go on 🙂
    Mark
