Hi all
This unit seems to fail to defrost itself properly. The defrost element is OK and I have changed the sensor once already (I am about to change it again as I got a couple of strange readings through the new one), I have also just sorted out the motorised baffle for the fridge section and checked that the freezer fan is working.
Before I go back again does anyone know of any other reason that it may be failing to defrost.
Is there a way of putting it into defrost mode?
Also does anyone have a wiring diagram and/or service manual for these please.
Thank you
Jem
