Whirlpool S20BRSB21 A/G
  • #47363
    johnnyj
    I have been asked to look at a Whirlpool S20BRSB21 A/G American fridge freezer, the evaporator is choked solid with an ice build up and the relays on the board are chattering good style, i’m not sure if a board will cure or i might need defrost heaters sensors and board, done plenty Hotpoint and Ge ones in my time but not seen many of these, JJ
    #293243
    jackster
    Re: Whirlpool S20BRSB21 A/G
    99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time the rear pcb is all that is required, the chattering is the relayt on the board. I think I have only changed a couple of de-frost heaters. A common fault is also that the bi-metal stat comes apart but the fact that the board is chattering almost certainley means new pcb 9depending on the serial you may need both)
    #293244
    johnnyj
    Thanks i’ll pop round tomorrow its a holiday letting company, i do work for the other letting companys in the area so getting this one as well will be a little boost. jj
