whirlpool s20d rsb33ag sn 8586 158 15010 which board
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool s20d rsb33ag sn 8586 158 15010 which board
  • #39175
    msappliance
    the above f/f is clicking, looking at previous posts it seems to be the board. when you open the fridge or freezer door it stops. appliance has defrosted.
    can you tell me if it is the boards that need replacing and which if not both.
    thanks, mike.
    #261538
    DentedPorsche
    Re: whirlpool s20d rsb33ag sn 8586 158 15010 which board
    Hiya, What is the serial number of the machine?
    Brian
    #261539
    msappliance
    Hi Brian,
    The only other number on the machine is
    11040 026 427.
    Thanks. Mike.
    #261540
    DentedPorsche
    Hiya, Serial number would indicate a later model with newer electronics so if the rear board is clicking it should only be that one to replace.
    Brian
    #261541
    msappliance
    thank you
    #261542
    roly16
    I’ve got the same machine, serial no. 110421013075 ; the rear board relay that supplies the water inlet valve is clicking on and off so the water is pulsing through the valve, and the customer complains of clicking starting when he opens the door, although I didn’t hear it. The appliance isn’t de-frosting.
    Do I need to change both boards or just the rear one, does anyone know?
    MS; did changing the rear board solve your problem?
    Geoff
